>> >> >> S2DA
- S2DA
S2DA
S2DAT
S2DA2T
9.
9.1
, , , 6, :
S2DA:
. S2DAT/S2DA2T:
(. 2, 2A, 2B)
(2.3)
(2.3), (2.4), ;
(2.3), (2.4).
(. 2, 2A, 2B)
(2.5)
(2.5), (2.6), ;
(2.5), (2.6), .
(. 7 7A)
9.2
6.
2 (. 2, 2A, 2).
, ( ), 200 , , , , , , .. .
D05
(., ) NYOGEL 760G ( ).
. 1: S2DA
   S2DA
.: A, B, C, H, X DIN-....
S2DA (. 1)
1.1
7.1
7.3
7.7
. 1A: S2DAT
   S2DAT
S2DAT (. 1A)
1.1
7.1
7.3
8.0
. 1B: S2DAT
   S2DAT
S2DAT (. 1B)
1.1
7.1
7.3
. 1C: S2DA2T
   S2DA2T
S2DA2T (. 1C)
1.1
7.1
7.3
8.0
. 2: 1250 A
1250 A (. 2)
. 2A: 1600+2000 A
  1600+2000 A
LIMIT STOP FOR THE CLOSED POSITION = LIMIT STOP FOR THE OPEN POSITION = MALE ARM = FEMALE ARM =
1600+2000 A (. 2A)
52/86
. 2B: 2500 A
  2500 A
2500 A (. 2B)
. 2C:
SECTION =
AXIS OF BASE =
LEVEL =
YES= NO=
"C" WASHER =
DETAIL =
SHIM=
55/86
LIVE PART FIXING =
. 2D:
YES = NO =
ALIGNMENT OF SEMIARMS=
THERE MUST BE NO SIDE LOAD DURING CLOSING= IN THE CLOSED POSITION THE MALE CONTACT MUST BE PARALLEL TO THE FEMALE CONTACT =
. 2E:
ICONTATTIFEMMINA DEVONO ESSERE PARALLELIAL BRACCIO MOBILE THE FEMALE CONTACTS MUST BE PARALLEL TO THE MOBILE ARM
LE LAME DEI CONTATTI DEVONO ESSERE PARALLELE, NON DIVERGENTI THE CONTACTS BLADES MUST BE PARALLEL AND NOT DIVERGENT
THE FEMALE CONTACTS MUST BE PARALLEL TO THE MOBILE =
THE CONTACT BLADES MUST BE CONVERGENT AND NOT DIVERGENT= ,
YES = NO =
. 2F:
2.0
« RH-BIECO   S2DA, S2DAT, S2DA2T - 245 362 »
