Типы съемных выключателей VM1, доступных для коммутационной аппаратуры UniGear
VM1/P съемный выключатель для коммутационной аппаратуры UniGear
Ur | Isc | Номинальный нормальный ток (40°C) | Тип выключателя | ||||||
кВ | kA | W = 650 | W = 800 | W = 1000 | W = 1000 | W = 800 | W = 1000 | W = 1000 | |
12 | 16 | 630 | VM1/P 12.06.16 p150 | ||||||
20 | 630 | VM1/P 12.06.20 p150 | |||||||
25 | 630 | VM1/P 12.06.25 p150 | |||||||
31.5 | 630 | VM1/P 12.06.32 p150 | |||||||
16 | 1250 | VM1/P 12.12.16 p150 | |||||||
20 | 1250 | VM1/P 12.12.20 p150 | |||||||
25 | 1250 | VM1/P 12.12.25 p150 | |||||||
31.5 | 1250 | VM1/P 12.12.32 p150 | |||||||
20 | 1600 | VM1/P 12.16.20 p210 | |||||||
25 | 1600 | VM1/P 12.16.25 p210 | |||||||
31.5 | 1600 | VM1/P 12.16.32 p210 | |||||||
20 | 2000 | VM1/P 12.20.20 p210 | |||||||
25 | 2000 | VM1/P 12.20.25 p210 | |||||||
31.5 | 2000 | VM1/P 12.20.32 p210 | |||||||
20 | 1600 | VM1/P 12.16.20 p275 | |||||||
25 | 1600 | VM1/P 12.16.25 p275 | |||||||
31.5 | 1600 | VM1/P 12.16.32 p275 | |||||||
20 | 2000 | VM1/P 12.20.20 p275 | |||||||
25 | 2000 | VM1/P 12.20.25 p275 | |||||||
31.5 | 2000 | VM1/P 12.20.32 p275 | |||||||
20 | 2500 | VM1/P 12.25.20 p275 | |||||||
25 | 2500 | VM1/P 12.25.25 p275 | |||||||
31.5 | 2500 | VM1/P 12.25.32 p275 | |||||||
17.5 | 16 | 630 | VM1/P 17.06.16 p150 | ||||||
20 | 630 | VM1/P 17.06.20 p150 | |||||||
25 | 630 | VM1/P 17.06.25 p150 | |||||||
31.5 | 630 | VM1/P 17.06.32 p150 | |||||||
16 | 1250 | VM1/P 17.12.16 p150 | |||||||
20 | 1250 | VM1/P 17.12.20 p150 | |||||||
25 | 1250 | VM1/P 17.12.25 p150 | |||||||
31.5 | 1250 | VM1/P 17.12.32 p150 | |||||||
20 | 1600 | VM1/P 17.16.20 p210 | |||||||
25 | 1600 | VM1/P 17.16.25 p210 | |||||||
31.5 | 1600 | VM1/P 17.16.32 p210 | |||||||
20 | 2000 | VM1/P 17.20.20 p210 | |||||||
25 | 2000 | VM1/P 17.20.25 p210 | |||||||
31.5 | 2000 | VM1/P 17.20.32 p210 | |||||||
20 | 1600 | VM1/P 17.16.20 p275 | |||||||
25 | 1600 | VM1/P 17.16.25 p275 | |||||||
31.5 | 1600 | VM1/P 17.16.32 p275 | |||||||
20 | 2000 | VM1/P 17.20.20 p275 | |||||||
25 | 2000 | VM1/P 17.20.25 p275 | |||||||
31.5 | 2000 | VM1/P 17.20.32 p275 | |||||||
20 | 2500 | VM1/P 17.25.20 p275 | |||||||
25 | 2500 | VM1/P 17.25.25 p275 | |||||||
31.5 | 2500 | VM1/P 17.25.32 p275 |
Примечания
W = Ширина коммутационной аппаратуры.
I = Расстояние между центрами полюсов.
u/l = Расстояние между основанием и главным выводом.
Ø = Диаметр изолирующей контакта.
24 | 16 | 630 | VM1/P 24.06.16 p210 | ||||||
20 | 630 | VM1/P 24.06.20 p210 | |||||||
25 | 630 | VM1/P 24.06.25 p210 | |||||||
16 | 1250 | VM1/P 24.12.16 p210 | |||||||
20 | 1250 | VM1/P 24.12.20 p210 | |||||||
25 | 1250 | VM1/P 24.12.25 p210 | |||||||
16 | 630 | VM1/P 24.06.16 p275 | |||||||
20 | 630 | VM1/P 24.06.20 p275 | |||||||
25 | 630 | VM1/P 24.06.25 p275 | |||||||
16 | 1250 | VM1/P 24.12.16 p275 | |||||||
20 | 1250 | VM1/P 24.12.20 p275 | |||||||
25 | 1250 | VM1/P 24.12.25 p275 | |||||||
16 | 1600 | VM1/P 24.16.16 p275 | |||||||
20 | 1600 | VM1/P 24.16.20 p275 | |||||||
25 | 1600 | VM1/P 24.16.25 p275 | |||||||
16 | 2000 | VM1/P 24.20.16 p275 | |||||||
20 | 2000 | VM1/P 24.20.20 p275 | |||||||
25 | 2000 | VM1/P 24.20.25 p275 | |||||||
16 | 2300 | VM1/P 24.25.16 p275 | |||||||
20 | 2300 | VM1/P 24.25.20 p275 | |||||||
25 | 2300 | VM1/P 24.25.25 p275 | |||||||
16 | 2500 (*) | VM1/P 24.25.16 p275 | |||||||
20 | 2500 (*) | VM1/P 24.25.20 p275 | |||||||
25 | 2500 (*) | VM1/P 24.25.25 p275 |
Примечания
(*) номинальный длительный ток 2300 A гарантируется с естественной вентиляцией. Номинальный длительный ток 2500 A гарантируется с принудительной вентиляцией.
