Типы съемных выключателей, доступных для модулей PowerCube
VM1/P съемный выключатель - VM1/W для модулей PowerCube
Ur | Isc | Номинальный нормальный ток (40°C) | Тип выключателя | |||||
кВ | kA | W = 600 | W = 750 | W = 750 | W = 1000 | W = 750 | W = 1000 | |
PowerCube | PB1 | PB2 | PB2 | PB3 | PB4 | PB5 | ||
12 | 16 | 630 | VM1/P 12.06.16 p150 | |||||
20 | 630 | VM1/P 12.06.20 p150 | ||||||
25 | 630 | VM1/P 12.06.25 p150 | ||||||
31.5 | 630 | VM1/P 12.06.32 p150 | ||||||
16 | 1250 | VM1/P 12.12.16 p150 | ||||||
20 | 1250 | VM1/P 12.12.20 p150 | ||||||
25 | 1250 | VM1/P 12.12.25 p150 | ||||||
31.5 | 1250 | VM1/P 12.12.32 p150 | ||||||
16 | 630 | VM1/W 12.06.16 p210 | ||||||
20 | 630 | VM1/W 12.06.20 p210 | ||||||
25 | 630 | VM1/W 12.06.25 p210 | ||||||
31.5 | 630 | VM1/W 12.06.32 p210 | ||||||
16 | 1250 | VM1/W 12.12.16 p210 | ||||||
20 | 1250 | VM1/W12.12.20 p210 | ||||||
25 | 1250 | VM1/W12.12.25 p210 | ||||||
31.5 | 1250 | VM1/W 12.12.32 p210 | ||||||
20 | 1600 | VM1/P 12.16.20 p210 | ||||||
25 | 1600 | VM1/P 12.16.25 p210 | ||||||
31.5 | 1600 | VM1/P 12.16.32 p210 | ||||||
20 | 2000 | VM1/P 12.20.20 p210 | ||||||
25 | 2000 | VM1/P 12.20.25 p210 | ||||||
31.5 | 2000 | VM1/P 12.20.32 p210 | ||||||
20 | 2500 | VM1/P 12.25.20 p275 | ||||||
25 | 2500 | VM1/P 12.25.25 p275 | ||||||
31.5 | 2500 | VM1/P 12.25.32 p275 | ||||||
17.5 | 16 | 630 | VM1/P 17.06.16 p150 | |||||
20 | 630 | VM1/P 17.06.20 p150 | ||||||
25 | 630 | VM1/P 17.06.25 p150 | ||||||
31.5 | 630 | VM1/P 17.06.32 p150 | ||||||
16 | 1250 | VM1/P 17.12.16 p150 | ||||||
20 | 1250 | VM1/P 17.12.20 p150 | ||||||
25 | 1250 | VM1/P 17.12.25 p150 | ||||||
31.5 | 1250 | VM1/P 17.12.32 p150 | ||||||
16 | 630 | VM1/W 17.06.16 p210 | ||||||
20 | 630 | VM1/W 17.06.20 p210 | ||||||
25 | 630 | VM1/W 17.06.25 p210 | ||||||
31.5 | 630 | VM1/W 17.06.32 p210 | ||||||
16 | 1250 | VM1/W 17.12.16 p210 | ||||||
20 | 1250 | VM1/W17.12.20 p210 | ||||||
25 | 1250 | VM1/W17.12.25 p210 | ||||||
31.5 | 1250 | VM1/W 17.12.32 p210 | ||||||
20 | 1600 | VM1/P 17.16.20 p210 | ||||||
25 | 1600 | VM1/P 17.16.25 p210 | ||||||
31.5 | 1600 | VM1/P 17.16.32 p210 | ||||||
20 | 2000 | VM1/P 17.20.20 p210 | ||||||
25 | 2000 | VM1/P 17.20.25 p210 | ||||||
31.5 | 2000 | VM1/P 17.20.32 p210 | ||||||
20 | 2500 | VM1/P 17.25.20 p275 | ||||||
25 | 2500 | VM1/P 17.25.25 p275 | ||||||
31.5 | 2500 | VM1/P 17.25.32 p275 | ||||||
24 | 16 | 630 | VM1/P 24.06.16p210 | |||||
20 | 630 | VM1/P 24.06.20 p210 | ||||||
25 | 630 | VM1/P 24.06.25 p210 | ||||||
16 | 1250 | VM1/P 24.12.16 p210 | ||||||
20 | 1250 | VM1/P 24.12.20 p210 | ||||||
25 | 1250 | VM1/P 24.12.25 p210 | ||||||
16 | 1600 | VM1/P 24.16.16 p275 | ||||||
20 | 1600 | VM1/P 24.16.20 p275 | ||||||
25 | 1600 | VM1/P 24.16.25 p275 | ||||||
16 | 2000 | VM1/P 24.20.16 p275 | ||||||
20 | 2000 | VM1/P 24.20.20 p275 | ||||||
25 | 2000 | VM1/P 24.20.25 p275 |
Примечания
W = Ширина коммутационной аппаратуры.
I = Расстояние между центрами полюсов.
u/l = Расстояние между основанием и главным выводом.
Ø = Диаметр изолирующей контакта.
